Intel(R) Core(TM) i5-3470 CPU @ 3.20GHz, 4 Kerne |
Speicher | 833.06 MB genutzt / 7.60 GB gesamt |
Lokaler HDD-Speicher | 49.56 GB genutzt / 866.27 GB frei / 915.83 GB gesamt |
ohne laufende Player liegt die CPU Last bei 1%
1 | root | 07:21 | /sbin/init |
376 | root | 07:21 | /lib/systemd/systemd-journald |
428 | root | 07:21 | /sbin/lvmetad -f |
436 | root | 07:21 | /lib/systemd/systemd-udevd |
520 | systemd-timesync | 07:21 | /lib/systemd/systemd-timesyncd |
782 | root | 07:21 | /usr/sbin/cron -f |
784 | root | 07:21 | /lib/systemd/systemd-logind |
789 | messagebus | 07:21 | /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd- ... |
814 | syslog | 07:21 | /usr/sbin/rsyslogd -n |
820 | daemon | 07:21 | /usr/sbin/atd -f |
822 | avahi | 07:21 | avahi-daemon: running [MS4L.local] |
865 | avahi | 07:21 | avahi-daemon: chroot helper |
824 | root | 07:21 | /usr/lib/accountsservice/accounts-daemon |
826 | root | 07:21 | /usr/sbin/acpid |
828 | root | 07:21 | /usr/bin/lxcfs /var/lib/lxcfs/ |
830 | root | 07:21 | /usr/lib/snapd/snapd |
862 | root | 07:21 | /usr/lib/policykit-1/polkitd --no-debug |
888 | root | 07:21 | /sbin/mdadm --monitor --pid-file /run/mdadm/monitor.pid --daemonise --scan --sys ... |
945 | root | 07:21 | /usr/sbin/smbd -D |
963 | root | 07:21 | /usr/sbin/smbd -D |
984 | root | 07:21 | /usr/sbin/smbd -D |
991 | root | 07:21 | /sbin/dhclient -1 -v -pf /run/dhclient.eno1.pid -lf /var/lib/dhcp/dhclient.eno1. ... |
1114 | root | 07:21 | /sbin/iscsid |
1115 | root | 07:21 | /sbin/iscsid |
1125 | root | 07:21 | /usr/sbin/sshd -D |
6588 | root | 07:30 | sshd: musik [priv] |
6779 | musik | 07:31 | sshd: musik@pts/0 |
6783 | musik | 07:31 | -bash |
1217 | root | 07:21 | /usr/sbin/irqbalance --pid=/var/run/irqbalance.pid |
1234 | root | 07:21 | /usr/sbin/nmbd -D |
1235 | root | 07:21 | /usr/sbin/winbindd |
1242 | root | 07:21 | /usr/sbin/winbindd |
8441 | root | 07:58 | /usr/sbin/winbindd |
1314 | root | 07:21 | /usr/sbin/apache2 -k start |
1394 | www-data | 07:21 | /usr/sbin/apache2 -k start |
1395 | www-data | 07:21 | /usr/sbin/apache2 -k start |
2965 | www-data | 07:23 | /usr/sbin/apache2 -k start |
2968 | www-data | 07:23 | /usr/sbin/apache2 -k start |
2971 | www-data | 07:23 | /usr/sbin/apache2 -k start |
4386 | www-data | 07:26 | /usr/sbin/apache2 -k start |
8161 | www-data | 07:34 | /usr/sbin/apache2 -k start |
9615 | www-data | 08:11 | /usr/sbin/apache2 -k start |
26329 | www-data | 08:21 | /usr/sbin/apache2 -k start |
27173 | www-data | 08:25 | /usr/sbin/apache2 -k start |
28927 | www-data | 10:54 | /usr/sbin/apache2 -k start |
29283 | root | 11:21 | sh -c ps --cols 2048 -eo user:80,ruser:80,group:80,rgroup:80,pid,ppid,pgid, pcpu, ... |
29284 | root | 11:21 | ps --cols 2048 -eo user:80,ruser:80,group:80,rgroup:80,pid,ppid,pgid, pcpu,vsz,ni ... |
2082 | root | 07:21 | /sbin/agetty --noclear tty1 linux |
3279 | root | 07:23 | sudo sc autostop |
3280 | root | 07:23 | /bin/bash /bin/sc autostop |
5310 | root | 07:29 | socat - udp4-listen:9001,reuseaddr,fork |
6716 | musik | 07:31 | /lib/systemd/systemd --user |
6721 | musik | 07:31 | (sd-pam) |
7972 | root | 07:34 | sudo /opt/music_server/mstools update_lms |
7973 | root | 07:34 | /bin/bash /opt/music_server/mstools update_lms |
7980 | root | 07:34 | sudo sc autostop |
7981 | root | 07:34 | /bin/bash /bin/sc autostop |
8215 | root | 07:35 | sudo sc autostop |
8216 | root | 07:35 | /bin/bash /bin/sc autostop |
9530 | root | 08:11 | sudo /opt/music_server/mstools update_lms |
9531 | root | 08:11 | /bin/bash /opt/music_server/mstools update_lms |
9538 | root | 08:11 | sudo sc autostop |
9539 | root | 08:11 | /bin/bash /bin/sc autostop |
9987 | root | 08:12 | sudo sc autostop |
9988 | root | 08:12 | /bin/bash /bin/sc autostop |
10566 | root | 08:14 | sudo /opt/music_server/mstools update_lms |
10567 | root | 08:14 | /bin/bash /opt/music_server/mstools update_lms |
10574 | root | 08:14 | sudo sc autostop |
10575 | root | 08:14 | /bin/bash /bin/sc autostop |
26820 | root | 08:24 | sudo /opt/music_server/mstools update_lms |
26821 | root | 08:24 | /bin/bash /opt/music_server/mstools update_lms |
26828 | root | 08:24 | sudo sc autostop |
26829 | root | 08:24 | /bin/bash /bin/sc autostop |
2 | root | 07:21 | [kthreadd] |
3 | root | 07:21 | [ksoftirqd/0] |
5 | root | 07:21 | [kworker/0:0H] |
7 | root | 07:21 | [rcu_sched] |
8 | root | 07:21 | [rcu_bh] |
9 | root | 07:21 | [migration/0] |
10 | root | 07:21 | [watchdog/0] |
11 | root | 07:21 | [watchdog/1] |
12 | root | 07:21 | [migration/1] |
13 | root | 07:21 | [ksoftirqd/1] |
15 | root | 07:21 | [kworker/1:0H] |
16 | root | 07:21 | [watchdog/2] |
17 | root | 07:21 | [migration/2] |
18 | root | 07:21 | [ksoftirqd/2] |
20 | root | 07:21 | [kworker/2:0H] |
21 | root | 07:21 | [watchdog/3] |
22 | root | 07:21 | [migration/3] |
23 | root | 07:21 | [ksoftirqd/3] |
25 | root | 07:21 | [kworker/3:0H] |
26 | root | 07:21 | [kdevtmpfs] |
27 | root | 07:21 | [netns] |
28 | root | 07:21 | [perf] |
29 | root | 07:21 | [khungtaskd] |
30 | root | 07:21 | [writeback] |
31 | root | 07:21 | [ksmd] |
32 | root | 07:21 | [khugepaged] |
33 | root | 07:21 | [crypto] |
34 | root | 07:21 | [kintegrityd] |
35 | root | 07:21 | [bioset] |
36 | root | 07:21 | [kblockd] |
37 | root | 07:21 | [ata_sff] |
38 | root | 07:21 | [md] |
39 | root | 07:21 | [devfreq_wq] |
44 | root | 07:21 | [kswapd0] |
45 | root | 07:21 | [vmstat] |
46 | root | 07:21 | [fsnotify_mark] |
47 | root | 07:21 | [ecryptfs-kthrea] |
63 | root | 07:21 | [kthrotld] |
64 | root | 07:21 | [acpi_thermal_pm] |
66 | root | 07:21 | [bioset] |
67 | root | 07:21 | [bioset] |
68 | root | 07:21 | [bioset] |
69 | root | 07:21 | [bioset] |
70 | root | 07:21 | [bioset] |
71 | root | 07:21 | [bioset] |
72 | root | 07:21 | [bioset] |
73 | root | 07:21 | [bioset] |
75 | root | 07:21 | [ipv6_addrconf] |
89 | root | 07:21 | [deferwq] |
90 | root | 07:21 | [charger_manager] |
137 | root | 07:21 | [kpsmoused] |
152 | root | 07:21 | [scsi_eh_0] |
155 | root | 07:21 | [scsi_tmf_0] |
156 | root | 07:21 | [scsi_eh_1] |
157 | root | 07:21 | [scsi_tmf_1] |
158 | root | 07:21 | [scsi_eh_2] |
159 | root | 07:21 | [scsi_tmf_2] |
171 | root | 07:21 | [scsi_eh_3] |
172 | root | 07:21 | [scsi_tmf_3] |
173 | root | 07:21 | [scsi_eh_4] |
174 | root | 07:21 | [scsi_tmf_4] |
175 | root | 07:21 | [scsi_eh_5] |
176 | root | 07:21 | [scsi_tmf_5] |
183 | root | 07:21 | [bioset] |
184 | root | 07:21 | [bioset] |
187 | root | 07:21 | [kworker/1:1H] |
257 | root | 07:21 | [raid5wq] |
283 | root | 07:21 | [bioset] |
311 | root | 07:21 | [kworker/0:1H] |
313 | root | 07:21 | [jbd2/sda1-8] |
314 | root | 07:21 | [ext4-rsv-conver] |
371 | root | 07:21 | [kworker/0:2] |
375 | root | 07:21 | [kauditd] |
394 | root | 07:21 | [kworker/3:2] |
427 | root | 07:21 | [iscsi_eh] |
433 | root | 07:21 | [ib_addr] |
439 | root | 07:21 | [ib_mcast] |
440 | root | 07:21 | [ib_nl_sa_wq] |
441 | root | 07:21 | [ib_cm] |
442 | root | 07:21 | [iw_cm_wq] |
443 | root | 07:21 | [rdma_cm] |
545 | root | 07:21 | [edac-poller] |
552 | root | 07:21 | [irq/28-mei_me] |
846 | root | 07:21 | [kworker/2:1H] |
910 | root | 07:21 | [kworker/3:1H] |
1156 | root | 07:21 | [kworker/2:3] |
8381 | root | 07:36 | [kworker/3:1] |
9424 | root | 08:06 | [kworker/1:1] |
10853 | root | 08:17 | [kworker/1:2] |
10856 | root | 08:17 | [kworker/0:0] |
28850 | root | 10:43 | [kworker/2:1] |
28859 | root | 10:45 | [kworker/u8:0] |
28959 | root | 11:01 | [kworker/u8:1] |
