One option would be a master/slave socket, but they are quite expensive for what it is. Another option would be to have some controlled socket that cuts the power to the speakers but unfortunately I'm out of controllable sockets in the kitchen. I was thinking of getting some controlled (zwave/zigbee?) plug adapters for just such purpose, which would add functionality to other things, but am not sure about that one yet.
Initially, I was hoping to find some signal sensing active speakers, but that turns out to be a bit more difficult than I anticipated: most are just usb powered and use the fact that a pc cuts usb power. However, for e.g. in my kitchen, a TV Soundbar could actually work (could be mounted above the window or so). For that purpose, the most entry level one would do and even those quite quickly have signal sensing. On the other hand, some speaker that could double as a handsfree set could be convenient in a kitchen...
Or are there simply relay circuits that one can use to trigger on/off from the Squeezebox? In one of mine, I use an ir blaster to power the amplifier it is connected to...
Thanks,
Jörg
