Disable motion input to lighting controller when turning the lights off
    I have a Lighting Controller with two I1 and I2 inputs switching the two lights on and off. Then a motion sensor input which switches a configured scene.
    The problem I have is when I switch off the lights (so no light is on) the motion is still detected and configured scene selected. I'd assume that if I turn off all the lights by I* input then the motion is disabled the same way as if using double click on any input.
    Thanks,
    Marek
  • duncan
    • 313
    theres a parameter to set the timeout after switching off, when the motion detector doesnt work
    i presume this is what you want - so you can turn the lights off and leave a room without the lights being triggered again
    on the lighting block its the Ti parameter set in seconds - i have most of my rooms set for between 2 and 5 seconds
      Yes I want to temporarily disable the motion sensor after switching the lights off. I have that parameter set properly. But it is not used when I switch the lights off by "I" inputs. It works when I double click any button or when I turn off the lights by scene inputs.
