Config v7.1.9.30 - EnOcean monitoring nogo; because extensions have lower firmware?
    Is it normal that the firmware of the extensions is on a lower version (7.0.9.7) than the Miniserver itself (7.1.9.30) ? I tried several reinstallation / firmware upgrades; no change. Can someone confirm this behavior, or is it only my installation?
    I didn't worry because everything seemded to function as should, but when I tried to learn some new serial numbers of Eltako FMH4 EnOcean switches, I saw that monitoring is not working at all, everything stays blank
    OK, is solved:
    • Prepared a new SD-card of 8 GB instead of the original 1 GB one
    • Uninstalled Loxone Config, then installed old version 6.4.6.17 of the config software, there everything worked fine: extensions get the same firmware version, and enocean monitoring works.
    • Then upgraded to 7.0.8.17 : different version for the extensions
    • Enocean monitoring was working, so upgraded to the current version: back where I started qua firmware versions, but Enocean monitoring is still working.
    Zuletzt geändert von zeki; 03.12.2015, 22:01.
