How to send value to thingspeak using virtual output command
    I'd like to send temperature value to thingspeak.com using Virtual Output Command (HTTP get request). Is it possible to append value at the end of the string?
    I've found the resolution "Value is used in the URL call <v>. You must also disable Use as digital output."
    • zimmema
      • 02.01.2021
      • 16
      Ich scheitere beim abrufen der Daten mit http Input, hat wer einen Tipp, was mache ich falsch ?
      versuche diesen Link aufzurufen:
      Leider bekomme ich nicht mal Daten rein sondern immer ein Fehlermeldung Code 500
      • Tico
        Tico kommentierte
        Do you use a Miniserver Gen1 or Gen2? https will only work with Gen2 (current model). Gen1 only works with http.
    • zimmema
      • 02.01.2021
      • 16
      I use the gen 2 Version.
      • Tico
        • 31.08.2016
        • 1035
        I can't see anything obvious why you're not getting data. I used the link you provided as is. The data is returned for both field1 and field2 with the following Command Recognition -
        <field1>\i<field1>\i\v
        <field2>\i<field2>\i\v
Name: Command Recognition.png
Ansichten: 112
Größe: 3,2 KB
        • zimmema
          • 02.01.2021
          • 16
          many thanks
          It works.
          The forcast in the Loxone Config doesn't work with this url.
          But i get the value in the VI.
          • Tico
            Tico kommentierte
            Sorry, I don't understand what you mean with "The forcast in the Loxone Config doesn't work with this url."?
