Nest Protect working with Loxone
  • Mikeseaman3000
    • 17.02.2018
    • 39
    Hello,
    I have a Loxone Miniserver on my property and looking to integrate NEST Protect with the Miniserver.
    I have been on Loxwiki and managed to get the NEST Developer system to work. I use the template (From Loxwiki) but nothing works, the values ​​from HTTP are read as 0.0 with no state change.
    Example I am reading from HTTP Address with Configuration "Is_online": \ v. This does not work. I have tried many combinations.
    I understand there have been problems with this. Has anyone fixed this?
    Thanks,
    Mike
  • Davejje
    • 24.11.2017
    • 173
    das würde besser funktionieren. Zumindest funktioniert es auf diese Weise
    "is_online \ s3 \ 1"
    Mit S3 überspringen Sie die ersten 3 Zeichen, bevor Sie den Wert betrachten.
    • Mikeseaman3000
      • 17.02.2018
      • 39
      Thanks Dave,
      I will give that a go this evening. Why are you skipping charactors before looking at the value. The value is a text return?
      I.e. "is_online":true,
      I am looking for true to show 1 and false to read 0.
      Thanks,
      • Davejje
        • 24.11.2017
        • 173
        Sie erhalten einen Wert von 114, wenn es online ist. Diese Werte entsprechen denen des Ansii-Modells. Sie finden sie unter:
        ASCII table, ASCII chart, ASCII character codes chart, hex/decimal/binary/HTML.
