Loxone’s VO’s don’t have any bidirectional communication. Every response from the destination is lost.
You may implement this with PicoC, or can use LoxBerry’s Any-Plugin to send TCP-Commands via Bash (e.g. netcat), and it will return the output via UDP.
Thanks for the quick response! I will go for the picoC solution. Perhaps do you know a script that i can use as an example? Anything that parses tcp commands into text is good.
