Hello.
I want to to arm the alarm automatically when the set of conditions is fulfilled.
- there are no smartphones in the wifi network
- there is no trigger for motion sensors for a while
- last triggered sensor - on the front door
The first point works for me. Question on the second and third.
Tell me, what blocks in the loxone config it can be implemented.
For 2.
Place a Switch-Off Delay https://www.loxone.com/enen/kb/switch-off-delay/ oy your page. Connect all motion sensor outputs to the Tr and define "a while" with the time parameter.
When all sensors did not detect for "a while", the output is 0.
For 3.
Place a flipflop (you may also take a switch) block on your page.
Connect the front door sensor to the S(et)-Input.
Connect all other motion sensors to the R(eset) connector.
The output of the flipflop is 1 if it was the last sensor triggered, otherwise it is 0.
