Stopwatch timer in Loxone
    Hi
    I'd like to implement a stopwatch in loxone so I can time the duration that my shower runs for and email me the results each time the shower is used. (I have a flow sensor on the shower supply that loxone currently uses to control the extractor fan, so I can use that as the trigger)
    Does anyone know of any easy ways to do this - I guess I can use the counter block and pulse/second, but I was hoping for something that would count up in hrs/mins/secs
    Steve
    • 11238
    The maintenance counter block is the easiest to implement this. It counts the time, and can give you a signal if a threshold is reached.
    Christian
      Thanks Christian, i'll have a play with that block.
      Steve
