I format the Micro SD card at laptop , then Miniserver isn't running !!
    I read the document , When I format the Micro SD card then insert it into Miniserver , only the Red led is on and other led flashed quickly . when I insert it to Miniserver !! I can't operator any thing . How can I do ?
    I just want to restore factory default !! who can help me !! thanks .
      • 5167
      Did you do this according to the instructions
        romildo , Thanks for your reply . I think I had a mistake , I format the sd card by Windows format programm. My god ! How can I repair the issue ?
        • MightyLox
          • 22.10.2015
          • 208
          Use the Loxone Config. Maintenance -> Format SD card.
          Haus: Neubau Start 22.11.15, EG/OG, 2 Pers./Kind/Hund, Massivhaus, Heizlast 7,52 KW
          Loxone: 1x MS, 2x Ext, 1x DMX
          KNX: 2x 8er & 8x 4er MDT Glastaster (mit Temp), Rollläden MDT AKU-1616.01, MDT AMI-1216.01 True RMS Steckdosen, MDT Wetter, MDT SCN-P360K4.01 Präsenzmelder
          Licht: DMX LED Beleuchtung (24V/230V)
          Heizung: LWWP Waterkotte Basic BS 7010.5, Webinterface Modbus TCP
          Projektseite: https://www.loxforum.com/forum/mein-...neubau-2015-16
            MightyLox , Thanks , Now the SD card is working , and two leds both are green . but I can't ping the default ip : 192.168.1.77 .
              Thanks , I found the ip address . After I format the SD Card , The network changed to DHCP mode .
