PicoC script for sending log-file from miniserver
  • sjef86
    • 23.08.2018
    • 4
    HI,
    Just wondered if anyone has a solution on sending a log-file from Loxone via email service?
    Would this be possible with a PicoC script?
    I have a file in my log-folder, that I wish to transfer every 24 hours, to a email receipiant.
    best regards
    Christian
    Have you tried to use external mail or Loxone mail instead the log?
    • sjef86
      • 23.08.2018
      • 4
      I've checked all the options that is available in the miniserver. But I need to adjust the format of the string. The format is built using a virtual status block, and then stored in a log.
      I then accumulate the chosen values in a common log-file, and then want to push this file out over mail, every 24hours.
      The reason for this, is that the receiving server/system requires to have the data sent in a specific way/format.
      Best regards
      Christian
