detect value change
  • J V
    • 367
    detect value change
    Hello,
    I'm trying to use the outcome of "unequals" to trigger another block.
    The problem is that the output Q of unequals does not refresh if the inputs change as long as the condition is met: if they are still unequal, the output stays 1.
    Is there an easy way to detect if an analogue value changes?
    Thanks!
  • J V
    • 367
    Just to update...
    In the unequals block, A1 is the output of a state, whereas A2 is a constant. I don't have that many possible values for A1, so I currently changed it to multiple "equals" block (one for each possible value, except for the one previously in the unequals block), each of which connects to a multifunction switch with a short output-time setting. The outputs of these multifunction switches are connected to the block I want to trigger. Any change of A1 changes the equals block that is matched and thus generates a new trigger. Typing this makes me wonder if the multifunction switches are at all necessary.
    It is a bit cumbersome as I need that many equals blocks and constants for each output of the state, but I don't see another way to generate a trigger. Still, hope it helps someone. :-)
      • 11234
      You may use this example to detect the change of an analoque value: https://www.loxwiki.eu/pages/viewpag...pageId=9339459
      • J V
        • 367
        Thanks!
        That functionality is very nice (but completely not explained in the description of the function block). It should make things a bit easier.
        (sorry, I should have searched through the wiki better)
        Zuletzt geändert von J V; 17.04.2019, 13:26.
        • J V
          • 367
          Somehow the delay does not work; it keeps changing the value as if the delay was not set...
          I output the AQ of a status block to two memoryflags, both set to analogue, one has a delay 0, the other a delay 1. On a change of the status, both contain the new value of the status...
            • 11234
            A Memory flag itself always has a delay of 1, so if using two memory flags, you need the delay 1 and 2.
            btw, you won’t see this, as 1 means 1 PLC cycle, and the PLC is running with around 100 Hz.
            • J V
              • 367
              Oh... I misinterpreted how it would work... I thought it kept the previous value (a bit like an analog memory). Thanks for the clarification!
