copy/paste: different object?
  • J V
    • 367
    Hello,
    Simple question... When you copy a bock in LoxoneConfig, and then paste it, is it the same block or a copy?
    Suppose I have a formula on page 1, and I copy/paste it in page 2. The one in page two has the same name as the one in page one. But are its values independent of the block? Or does it depend on the block?
    At the moment I add new blocks to avoid any problems, but it is much more work...
    Thanks,
    Jörg
  • Automation
    • 23.08.2015
    • 663
    It's a independent copy, means it looks the same but it is a own eleme t. Ir you change one, the one you have copied stays as it is.
    Gesendet von meiner Steintafel mit Tapas
    En Gruäss us de Schwiiz
    KNX seit 2005
    Miniserver seit Jan. 2011
    • J V
      • 367
      Thanks... I somehow had the impression some of the inputs changed together with the original and was not sure what the best way was to verify this... Guess I must have missed something else.
