something i came across today and can't figur out why an On and On on an and port won't give me on?
Doens't it work on equal states?
to be clear in the picture you will see dutch but here is the translation
AAN = ON
UIT = OFF
i initialy had no equal block but it didn't work then, so i thought that maybe 'afwezig' (translated noone at home) was an analog output.
That's why i placed the equal block but still no change behind the and port.
I did understand you. and it fixed the problem, only i don't know why...
Placing the connections in parallel or trought 'OR' ports shouldn't make a difference.
Or is it because i use KNX push buttons? Do the or ports have an internal 'ON' detection (Flank trigger)
