Perhaps a strange question, but how do I best set the initial value of e.g. memory flags or radiobuttons when the miniserver boots up?
I have a configuration where I compare values, but as it is now the moment it might not work depending on how the values are at boot up time.
To initialize them at boot, is it sufficient to e.g. constant to an analog memory, trigger it with a pulse from startup, and connect the output to the input of the memory flag? I suspect this will trigger this particular value at boot, but is it true that any change to another line connected to the same input of the memory flag will be considered?
Thanks,
Jörg
