Tree Spot UK will not mix mood to change brightness if motion.
  • edipseamm
    • 03.02.2020
    • 58
    Hello.
    I currently have tree UK spotlights attached to a v2 lighting controller. I have them set up to come onto 'dim' mood at dusk and want them to switch to 'bright' when there is motion. Then at dawn, the lights go off.
    At present this seems to work in principle as it reports 'multiple moods selected' when there is motion but the lights do not actually change brightness. Also if I try to select both moods within the app it just takes priority to whatever was selected first.
    Loxone support said I needed support for this I needed to come for training... So I'm hoping someone can help me out here.
    See attached config.
    TY
  • edipseamm
    • 03.02.2020
    • 58
    Update Resolved.
    You need to make a different lighting circuit. Then set the different moods between AQ1 and AQ2. If you are using the same lights for AQ1/2 then you just connect them up on the output.
