If there was a web service that could do this from a virtual input it might work but I have been told there is not.
Controlling overall brightness with a retractable switch
Ok I am working on a project which the end user wants an area that is covered by multiple lighting circuits to be controlled by switches on a wall. We are using Gmatrix push switches throughout. Some switches will turn on 1 circuit out of 6 (i.e desk lamp). I orginally planned this to just be removed or added to a mood. Now my main issue is if the main light is at 80% two others at 50% and the others off, the clients wants two switches assigned to (+) and (-) to dimmer the mood (scene) this would be the same as using the overall brighness in the UI. As far as I know there is no input on the function block that can adjust the overall brightness of a scene. Has anyone else wanted to do something like this.
If there was a web service that could do this from a virtual input it might work but I have been told there is not.Stichworte: - -
yes it can be done using buttons connected to a dimmer block and connect the output of the dimmer to a virtual output which drives the lighting blocks master dimmer via the api
Hallo in die Runde, Achtung - das ist mein erster Eintrag hier ;) Trotz vorheriger Recherche hier komme ich nicht weiter. Vielleicht habt ihr einen Ansatz. -
Angehängte Dateien -
Hallo in die Runde, Achtung - das ist mein erster Eintrag hier ;) Trotz vorheriger Recherche hier komme ich nicht weiter. Vielleicht habt ihr einen Ansatz. -Kommentar
