Sidenote: taking the SD card out of the miniserver seems to have zero impact on the miniserver, the card is also completely empty when we read it on a laptop.
Loxone Formatting Error
We are trying to do a factory reset of our Miniserver Gen 1. To do this we have to format the SD card in windows, then use the loxone config to format the SD card. However when this is halfway through it throws an error for "make sure the sd card isn't locked an in the PC". It does this for multiple SD cards (We used the original Loxone SD first). We are doing this because we no longer have access to the administrator account of the miniserver.
Sidenote: taking the SD card out of the miniserver seems to have zero impact on the miniserver, the card is also completely empty when we read it on a laptop. -
Format the card in Windows.
Then, run Loxone Config as administrator.
Disable any virus scanner before of formatting from Loxone.Hilfe für die Menschen der Ukraine: https://www.loxforum.com/forum/proje...Cr-die-ukraineKommentar
You could try a different formatting tool -
https://www.sdcard.org/downloads/formatter/
Check the boxes that say "Overwrite format" and "CHS format size adjustment". That should get rid of any bad sectors.
Then also format them in Windows and de-select "Quick Format".Zuletzt geändert von Tico; 08.03.2020, 14:38.Ich spreche kein Deutsch. Gib Google Translate die Schuld, wenn ich unverständlich bin.Kommentar
