I am facing with a problem connecting to miniserver.
The situation:
Miniserver static IP: 192.168.1.77
Router IP: 192.168.8.1 (if it matters)
PC Static IP: 192.168.1.8 (I set that by myself in order to work)
Miniserver is connected with LAN cable to the router as well as PC. Then I am able to connect to miniserver (but have no internet connection on PC because of static IP under IPv4 settings. Also when looking through CMD with command "arp -a", I see miniserver on the list with the same IP 192.168.1.77. When I try to ping this IP, I receive the signal back.
Once I change PC ipv4 IP to dynamic, then I have internet connection on my PC, but cannot connect Miniserver anymore. On Loxone Config when I search for Miniserver it is found in the list under the same IP 192.168.1.77, but cannot connect to it. When I look on CMD with "arp -a", I can't see miniserver anymore and can't ping it.
So it leads to the problem that I can config miniserver while connecting to it directly, but cannot connect through wifi or ethernet while having internet on my PC with dynamic IP. Also I cannot connect to loxone app.
Could anyone explain me or tell me what should my steps be in order to connect to the Miniserver? I understand that I missed something and probably have lack of knowledge with network "things"...
