Mood Templates?
    Mood Templates?
    Hi, I have just purchased an apartment that has LOXONE system throughout. I am all logged in and setup in both the config and UI apps.
    The current setup has a mix of English and Danish for mood names, and some are redundant. I want to set every light to have the same moods defined and parameters (off, dim, normal, bright). I have dozens of lights, wondering if there is some way to define some sort of shared mood template and set every light to use that? Or must I got to each and every light and define the same entries over and over?
    Thanks,
    Brett
