Pulse x minutes before Sunset ?
  • Sliderem
    • 30.06.2018
    • 60
    Hello,
    Do you have an idea how I can create a pulse for for x minutes before the sunset or after the sunrise ?
    I know that we have Pulse for Sunrise/Sunset Dusk/Down but it doe not allow too much flexibility.
    Also I tried to use Daylight 30 minutes , but it is On/OFF not a simple pulse.
    The use case is the following :
    1 hour (or x minutes) before the sunset , when the light is already lower outside, I would like to trigger down the privacy stores.
    Thank you in advance!
    • 11234
    This is the same use-case:
    Hello all. I am trying to introduce a variable time to switch on the lights in my courtyard in the morning before sunrise. The idea is that the lights will go on about 1 hour before sunrise, and after about 1 hour be turned off via the KNX daylight sensor. I have arranged the Loxone time sunrise, combined it with an Loxone ADD
    • Dostal
      • 22.02.2016
      • 318
Ansichten: 457
Größe: 24,1 KB
      • hme0354
        hme0354 kommentierte
        he dont't wants an impulse after sunset, he wants an impulse before sunset
      • Dostal
        Dostal kommentierte
        yes... why like more?... e little bit creativy and you have your function
    • Sliderem
      • 30.06.2018
      • 60
      Super, thank you very much for all the responses. Indeed before sunset !
      I did the modify . I hope it will work!
Ansichten: 395
Größe: 11,5 KB
