I have been struggling with the miniserver to send out an MQTT command.
I have the impression I have done everything right following the instructions about how to use the Loxberry MQTT gateway but my Virtual Output command does not get picked up by the broker.
The examples are made for Shelly but I would expect it to work with any subscribed MQTT device. At least the broker should see it, regardless of the intended target ...
The broker get the command 'keepaliveepoch' coming from the miniserver just fine but when I use the VO nothing happens. I used many differents way to write the command but none seems to work. (with 1 and 0, On and Off ...).
The Input direction of the setup does work perfectly and I can use MQTT to activate the switch in the Miniserver.
Does anyone have an idea of what I'm doing wrong? Let me know if more information is needed...
Thank you!
Tom
