Variable values in MQTT commands
    I have another question about how to manage values in the Miniserver through MQTT.
    I would like to manage what could be understood as a dimmer (a value ranging from 0 to 100%). Is it possible to send/receive a variable value through the MQTT gateway?
    What would the command look like to pick up a value inside Loxone and send it to the broker?
    Thanks!
    • 11234
    publish to/my/topic <v>
    The output needs to be set Digital=No
    If you require json payload, this could look like
    publish to/my/topic { "bright" : <v>}
    ​​​​​​(as a generic example, depends on the payload requested by the device)
    Zuletzt geändert von Christian Fenzl; 07.03.2021, 16:16.
      Thanks! That was easier than I expected. Worked on the first go .
