How to reopen a closed pane?
Can you show Screenshots or decribe your problem more in detail?Smarthome: 1x Miniserver Gen. 2, 3x Relay Extensions, 1x Tree Extension, 1x DI-Extension, 1x Air Base Extension, 8x RGBW Tree Dimmer, 9x Touch-Tree, 1x Nano DI Tree, 10x Tree BWM
Technik: IDM Aero SLM 3-11 mit HGL, MS4H mit 9 Zonen, 2x Loxberry, 2x RPI für Anzeige, Doorbird, Froggit WH2600, POE+ System für Peripherie, Gedad Luftgütesensoren, Deconz (Bridge + 2x BWM + 2x RGBW + 5 Smartplug) -
To reopen the properties, move with your mouse to the left and wait until the window opens,
after that click on the nail in the right top corner to fix the window.
Nur ein Netzwerkkabel ist richtiges WLANKommentar
In Config there are three panes: Miniserver periphery by default on the left, project in the middle and properties on the right (it will display the properties of a selected block). I can move these panes and I can also close them. I could not find anywhere how to reopen them when closed. In other apps there is usually a menu called windows but it is not the case here. You can see the three panes for example here, but in a different order https://www.loxone.com/enen/wp-conte...iniserver3.pngKommentar
Click on the button VIEW between Zoom minus and Project Backups in MY PROJECT category.
Activate DISPLAY PROPERTIES ON THE LEFT BELOW THE PROJECT TREE.
Now you have your properties underneath the tree.FG
