I want my motion sensors to activate a different mood depending on an operating mode. Seems easy to do in a light controller block, using the "Automatic" tab, but for some reason it just don't work.
When I save-in my project to the miniserver, it kinda works, but it seems that, once the operating mode changes, my lights still trigger the mood for the old state of the operating mode.
So I think the operating mode does not dispatch it changed state.
The operating mode is set by using a Schedule block, and is attached to the AQ output. It is set as digital output. In simulation mode, all works fine.
Should I use a trigger? How?
By the way, I did not want to use the already existing Night mode, because I wanted a new, independent mode, that is working with a Schedule block only.
Any tips on what might go wrong?
Thanks!
Gert
