I am trying to configure 2 alarms. At least, that's what I think I have to do to solve the case I have at home...
My issue is that I have a cat, and it's sometimes at home, sometimes not. So when leaving the house, I activate the alarm. But whenever the cat is at home, I want some motion sensors to be disabled (via a switch available in my User Interface), so that these can't trigger an alert due to the cat moving around in the concerned part of the house.
So my solution (maybe not the best one, any -better- alternatives may be proposed) is to configure 2 alarm function blocks. They both have the same outputs (mainly silent alarm and light alarm outputs) configured. As inputs, the one ("main") alarm has the set of motion sensors which are to be always enabled, and the other one (the "cat" alarm) only has the set of motion sensors which should be enabled or disabled whenever the cat is respectively out or in.
Now my problem is that when the main alarm is active, and I activate the "cat" alarm (input V of the "cat" alarm function block), its Q1 output is activated. I have tried everything I can imagine, but I can't succeed in activating the cat alarm without it causing an alert trigger. Both alarms are activated by the same pulse.
What could I be doing wrong ?
