My system is KNX, so I used KNX/EIB buttons. They can take the current status from the KNX bus and show this on the button position.
1. Can you do the same for normal buttons?
Suppose I want a switch that shows some current status (which comes from an external source), how can I show the status for the button? An example could be a power switch for a pc (status on/off determined by ping), or a power switch for squeezebox player? How do you get the status? Or do you then just use the KNX/EIB button with appropriate inputs?
2. How do you make a button that does not show a status?
A bit like a button on a web page: you click it to trigger something, but it does not show a state.
Thanks!
Jörg
