Control webpage button via virtual ouput
  • Doba
    • 24.06.2023
    • 4
    I'm totally new to virtual inputs and outputs and could use some help.
    For the last couple of days I've been trying to get Loxone to virtually press a button on a webpage with the virtual output function.
    The webpage (http://192.168.1.202) requires a login. The username: admin & password: 1234567.
    I've tried lots of combinations in command but it hasn't been going great yet.
    The basic setup is visible in the screenshots.
    The button I want Loxone to press is the one with the arrow.
    Any suggestions?
  • Tico
    • 31.08.2016
    • 1035
    My sense is that this won't work unless the controlled device has a dedicated API to accept commands via HTTP. I haven't seen any examples of someone interfacing with a web-page as you propose.
    It is possible with an external device like a Raspberry Pi. A Raspberry Pi with appropriate software like Puppeteer can be commanded via a Loxone Virtual Output. The Virtual Output triggers a script to login to the web-page, then click any desired element. It can additionally scrape the results for a particular field and return that value to Loxone via UDP.
