Lighting Controller - default mood with manual operation
I want to select the default mood when pressing our bedroom light switches manually, but have the mood change depending on a pre-condition. In our case, I want the lights to go into a low 'night mode' when the room is in a 'Sleeping mode', but otherwise I want the controller to select a different mood (i.e. 'all on').
I understand how to use the Automatic setting which changes the mood when motion is detected. This gives exactly the behaviour I need, because different moods can be selected based on the active operating mode. But I've struggled to find a way to do this when manually operating the lights.
This is the best I've come up with, which is a bit clunky but works well:
Does anyone have any work-arounds or a more sensible / cleaner solution?
