Touch Pure Flex set mood based on current value
  • johnsmith_
    • 24.03.2022
    • 27
    Hey!
    I have a couple Touch Pure Flex around the house and I can't seem to make it work as I want them to work. So the basic idea would be that when I press the "light" button, it would either set the mood to ID 0 or 99, based on the current mood value. Let's say I have 5 moods in the lighting controller, with ID 0, 1, 2, 3, 99, 0 being all off, 99 being all on. If the current mood is NOT 0, then it would set the mood to 0. If the current mood IS 0, then it would set the mood to 99. Also with the arrows I should be able to cycle through all the moods.
    I can have SET(Lico, Mood) assigned to the button and assign SET(Lico, M-) and SET(Lico, M+) to the arrows, but obviously that won't work as I described.
    I would also be fine with something like single click setting the mood to 99 and double click setting it to 0, arrows cycling through the moods, but I can't find a way to do that either. Am I missing something or basically there's no way to simply turn on/off lights without cycling through the whole list of moods?
