HTTP Get request with header authentication
  • Pilaarbijter
    • 21.11.2020
    • 39
    Hello everyone,
    In short I have this WIFI-heater from Adax that I would like to command to change the temperature via theLocal API
    (link)
    Snippet of most important information on the above mentioned site:
    Klicke auf die Grafik für eine vergrößerte Ansicht  Name: snippet.jpg Ansichten: 0 Größe: 66,5 KB ID: 428049
    I am trying to get a HTTP get request done via Loxone but I don't seem to get it working. I added printscreens of what I have in Loxone thus far. I probably need the Unix time
    from Loxone but I can't wrap my head around how to import it into my request.
    Klicke auf die Grafik für eine vergrößerte Ansicht  Name: hoofd.jpg Ansichten: 0 Größe: 69,6 KB ID: 428050
    Klicke auf die Grafik für eine vergrößerte Ansicht  Name: input.jpg Ansichten: 0 Größe: 129,5 KB ID: 428051
    I programmed the same request in a Python script and everything is going flawlessly. (code below)
    This leads me to believe that there probably is a problem with the concept unix time that is required to run the command.
    I'm planning on making a full HowTo about this adventure, so any help here would be great for the community aswel
    Working Python-code
    #! /usr/bin/bash python3
    # controls heater
    # install dependencies with: pip install bleak requests
    import http.client
    import urllib
    import time
    import requests
    import urllib3
    HEATER_IP = '192.xxxxxxx # replace with your heater IP from the prepare_demo
    HEATER_TOKEN = 'xxxxxxx' # replace with your secure password from the prepare_demo
    def get_status():
    url = 'https://' + HEATER_IP + '/api'
    payload = { 'command': 'stat', 'time': int(time.time()) }
    headers = { 'Authorization': 'Basic ' + HEATER_TOKEN }
    response = requests.get(url, params = payload, headers = headers, timeout = 15, verify = False)
    response_json = response.json()
    target_temperature = response_json["targTemp"]
    current_temperature = response_json["currTemp"]
    print('Current temperature %d, target temperature: %d \n' % (current_temperature, target_temperature))
    urllib3.disable_warnings() # heater uses self signed certificate
    get_status()
    exec(open('PushoverDown.py').read())
  • Tico
    • 31.08.2016
    • 1035
    Replace <v1> with <v>. Only <v> is accepted in a Virtual Output.
    If <v> is used, the expectation is that the Unix Timestamp would be at the entry to the Virtual Output. Use as Digital Output should be unchecked. The Unix Timestamp is available in the Time functions -
    Klicke auf die Grafik für eine vergrößerte Ansicht  Name: Unix Timestamp.png Ansichten: 0 Größe: 7,7 KB ID: 428057
    But this would also mean a command is sent on every change (every second).
    You really need a Status Block with a trigger to allow the Timestamp through only when desired. This also sends a 0 on Off. This may be an issue without testing.
    Klicke auf die Grafik für eine vergrößerte Ansicht  Name: Trigger.png Ansichten: 0 Größe: 16,4 KB ID: 428058
    Zuletzt geändert von Tico; 30.03.2024, 02:11.
    • Pilaarbijter
      • 21.11.2020
      • 39
      Thanks for the reply!
      Sadly the adaptations to this set-up don't seem to work.
      Klicke auf die Grafik für eine vergrößerte Ansicht  Name: config.jpg Ansichten: 0 Größe: 16,3 KB ID: 428137
      Klicke auf die Grafik für eine vergrößerte Ansicht  Name: config2.jpg Ansichten: 0 Größe: 8,4 KB ID: 428138
      I was able to verify the following command via Postman without any issues (it increase the desired temperature to 14 degrees celcius):
      https://192.xxx.x.xxx/api?command=set_target&value=1400&time={{$timestam p}}
      This leads me to believe that there is a problem in Loxone with the Unix Timestamp not being transported into the URL properly.
      EDIT:
      I also considered your remark regarding the zero/off value being a potential problem. Although it might be responsible for an overload of commands towards the heater, it does not explain the problem of the temperature not changing (since a request sent is a request sent (I think).
      Zuletzt geändert von Pilaarbijter; 30.03.2024, 22:53.
      • Tico
        • 31.08.2016
        • 1035
        I'm more inclined to think it may be a problem with the 'HTTP header for On'. Just change your token to something false and send a screenshot of exactly how the line looks.
        edit:
        And what does the Postman header look like?
        The other issue may be the 'https'. Are you on a Miniserver Gen1 or Gen2?
        Zuletzt geändert von Tico; 30.03.2024, 23:01.
        • Pilaarbijter
          • 21.11.2020
          • 39
          Could you specify on 'how the line looks' that you would like to see? I'm not really sure what you mean by that. A diagnostic report of sorts?
          Set-up in Postman:
Ansichten: 766
Größe: 37,4 KB
          Token is set up: Basic xxxTOKENxxxx
          I reckon my server is Gen 2. It was installed in 2019 and is limegreen.
          • Pilaarbijter
            • 21.11.2020
            • 39
            Nevermind, I'm such an idiot. I forgot to add the "Authorization:" to my header for on in Loxone. Unbelievable.
            Thanks for the help though, it's much appreciated
            • Tico
              • 31.08.2016
              • 1035
              I thought this looked a bit short....
Name: HTTP Header.png
Ansichten: 747
Größe: 41,7 KB
              • eIRIk
                • 27.03.2018
                • 13
                Did you get adax to work? If yes. How did you request the token? Did you use the program block?
                Miniserves v1 & v2 v14.7.3.6, Test Miniserver v1, Relay Ext., 7xDimmer Ext., 1-Wire Ext. Modbus ext., Air Ext, RS485 Ext. 8xRGBW Dimmer Ext, Tree Ext., 2xtree to air, Wether station, KebaContact P20, Intercom +++ Loxberry: MiRobot2Lox, TinyTuya Ventilation: System Air via Modbus RTU AMS: PowU, HomeConnect, PowerWiew Shading, Husqvarna Automover
