Vacuum cleaner and alarm
  • Daruda
    • 02.09.2022
    • 3
    Hi all,
    Maybe a very simple solution, but I was not able to find it directly.
    We have a roborock vacuum cleaner and want to program it to work daily on a specific timestamp.
    As we won't be home all the time there is also a chance the alarm is on.
    Is it possible in loxone to program that for a specific hour, if the alarm is on, presence detection should be turned off for that hour so that the robot can do the cleaning?
    Possible with automatic rules or better solutions?
    Thanks
  • harisd
    • 29.07.2024
    • 5
    I assume you have already looked, but just in case, can you not do it through the automatic designer and setting the time as input parameter?
    Also, probably a silly question, but if the vacuum does not emit any infrared (unless it does to detect the base station or obstacles), is it still detected by the presence detection sensors?
