Gateway / Client
  • Daniel82
    • 30.08.2024
    • 8
    Gateway / Client
    Hello ,
    I have a project with 8 miniserver .
    I try to connect each other with gateway Client method . But not working I tried everything .
    the Client always stay offline .
    IP address is in the same range
    Everything is in the same network
    user and password are the same
    i use static IP
    default gateway is the same
    I tried two different router
    I tried only with switch as well!
    Internal address is ok (I not use host name)
    I double checked the network settings with
    (IP address)/admin
    i did Health check
    I use same firmware
    Anyone have any suggestion?
    is necessary special router set up?
