Time format when using API
  • swindive
    • 29.11.2024
    • 2
    Hi
    I'm writing a simpe app to allow club members to press a button on a web site which will turn the heating (comfort timer) on for 1 hour.
    I have worked out the API call, but cannot work out the time aspect of the API call.
    The API call looks like this.
    https://<IP>:<PORT>/jdev/sps/io/<controller>/override/<setting>/<time>
    Setting = 1 : Comfort Timer
    Setting = 0: Eco Timer
    If I omit the time portion then the default seems to be 23:59 on the same day.
    For today (29th November), if I use the interface and at 22:20, set the override for 10mins, I get the number 502151400. Any ideas what calculation is used to generate that number. Its clearly not epoch time.
    Thanks.
    Nick.
    • 11234
    This presumably is the "Loxone Epoch" from 1.1.2009.
    Here is how to convert: https://github.com/mschlenstedt/Loxb...ystem.php#L964
    • swindive
      • 29.11.2024
      • 2
      Thanks for the info, I'll check it out. Much appreiated.
      Nick.
