Tracker - how to add info about user who performed action
Good question.
I think this is not possible and would need a bigger change in the Loxone firmware.
For example, you push a button in the App, that triggers an action in some other function block that you track. So the user name would have to be chained from your button to the tracker. And what if some logic triggers things?
So if Loxone would implement that, this feature will have a wide spectrum of failures.
It was meant that this functionality is available only on "input" type of components (function block).
In text (message) which goes today in tracker (message text) I can use pass on value <v> as current value of (this) component. Is it possible to reference value of some other component - eg: when something happens I create text log in Tracker. In text/message I would like to add value of some other component (eg. value of memory flag - eg message text where I reference battery voltage: Network power outage detected, battery voltage <battery.v>)
