sauna control
  • muflon_
    • 01.08.2016
    • 11
    sauna control
    Hi guys, is there any recomendation for sauna heater (with or without evaportator) which will be compatible with loxone sauna block?
    • 11234
    Every sauna heater is compatible if you do not use the included control.
    But keep in mind, that in this case you are responsible to build in all the safety features your original control has.
    I have collected the implementation of my own sauna heater with evaporator in this (German) document (see below). An electrician should support you for this project, if you aren't.
