Program Issue
    Program Issue
    I need to activate the lightning controller with a scene which is only one pulse. But i have only have a 1 or 0. Has somebody has a idea how to program this.
    Thanks in advance,
    Beano
    • 11234
    You can use the Wiping Relay. Use an impulse time of about 0,1 seconds.
    Christian
      Thanks Christian,
      I've tried this this but if the trigger is "On" the Q stays also."On" At this moment i need only 'one" pulse to trigger the scene
      rgs,
      Beano
      • Jan W.
        • 30.08.2015
        • 1366
        I thought that Christian was right, but you may try the monoflop, see http://www.loxone.com/enen/service/d.../monoflop.html
        Node-RED: IKEA Tradfri
          Hi Jan ,I've tried this also but if the Trigger stays "on" the Output stays "on". I woud like that the Output only make a pulse. Hopefully someone has a answer for this.
          Thanks,
          Beano
          • Robert L.
            Robert L. kommentierte
            no, the monoflop stays "on" only for the time you configure with the "T" parameter,
            if this is 0,001 you have only one "Puls"
          • 11234
          Gast Please post a screenshot of your configuration in LiveView that shows all current states.
            Hi Guys, I think it is going to work with the monoflop, somehow i did something wrong but it seems to work now. Thanks for the advices
            Beano
