set parameter depend on output state
  • muflon_
    • 01.08.2016
    • 11
    Hi guys,
    how can I set diferent memory flag depends on output state? for example burglar alarm output AQ has two states (or three) 0,1 and 2 which depends on burglar alarm status. I need to set commad via RS485 when is AQ on 1 and different command when si AQ on 2.
    Many thanks
  • mbj3000
    • 21.07.2016
    • 31
    For example, use "status", put your command into the text Field and use the text result for further processing..
