or via Google Translate -
The PicoC program runs successfully for those outputs triggered by AI2 ('Forecast Today', 'Forecast Tomorrow' and 'Forecast day after Tomorrow').
The outputs triggered by AI1 (listed below from the Loxone Log file) run successfully for one iteration. The second triggering of the AI1 input causes a 'memory not valid' error. In the log example below, it's triggered every 3 minutes.
I don't know what Loxone version the PicoC program was written for, however when importing the .loxone file from the link above, a message says "Note: The document was adjusted to be compatible with the latest version. Please save the changes!". I suspect this adjustment may be the issue (or the bug might be integral to the original file).
I'm running Loxone v7.4.4.14
2017-01-23 08:56:06.187;Wunderground-API: observation_time:Last Updated on Januar 23, 08:56 AWST
2017-01-23 08:56:06.265;Wunderground-API: magic:10
2017-01-23 08:56:06.339;Wunderground-API: wmo:94608
2017-01-23 08:56:06.417;Wunderground-API: latitude:-31.939238
2017-01-23 08:56:06.491;Wunderground-API: longitude:115.851273
2017-01-23 08:56:06.569;Wunderground-API: elevation:25.9
2017-01-23 08:56:06.645;Wunderground-API: weather:Heiter
2017-01-23 08:56:06.721;Wunderground-API: temp_c:21.2
2017-01-23 08:56:06.797;Wunderground-API: relative_humidity:50%
2017-01-23 08:56:06.871;Wunderground-API: wind_degrees:259
2017-01-23 08:56:06.951;Wunderground-API: wind_dir:West
2017-01-23 08:56:07.025;Wunderground-API: wind_mph:6.0
2017-01-23 08:56:07.101;Wunderground-API: wind_gust_mph:7.4
2017-01-23 08:56:07.177;Wunderground-API: wind_kph:9.7
2017-01-23 08:56:07.253;Wunderground-API: wind_gust_kph:11.9
2017-01-23 08:56:07.331;Wunderground-API: pressure_mb:1017
2017-01-23 08:56:07.409;Wunderground-API: pressure_in:30.04
2017-01-23 08:56:07.483;Wunderground-API: pressure_trend:0
2017-01-23 08:56:07.561;Wunderground-API: dewpoint_f:51
2017-01-23 08:56:07.635;Wunderground-API: dewpoint_c:10
2017-01-23 08:56:07.711;Wunderground-API: heat_index_f:NA
2017-01-23 08:56:07.789;Wunderground-API: heat_index_c:NA
2017-01-23 08:56:07.865;Wunderground-API: windchill_f:NA
2017-01-23 08:56:07.941;Wunderground-API: windchill_c:NA
2017-01-23 08:56:08.013;Wunderground-API: feelslike_f:70.2
2017-01-23 08:56:08.091;Wunderground-API: feelslike_c:21.2
2017-01-23 08:56:08.167;Wunderground-API: visibility_mi:6.2
2017-01-23 08:56:08.243;Wunderground-API: visibility_km:10.0
2017-01-23 08:56:08.319;Wunderground-API: solarradiation:575
2017-01-23 08:56:08.395;Wunderground-API: precip_1hr_in:0.00
2017-01-23 08:56:08.471;Wunderground-API: precip_1hr_metric: 0
2017-01-23 08:56:08.547;Wunderground-API: precip_today_in:0.00
2017-01-23 08:56:08.623;Wunderground-API: precip_today_metric:0
2017-01-23 08:56:08.625;Wunderground-API: Last Updated on Januar 23, 08:56 AWST
2017-01-23 08:59:08.152;memory not valid
I'd be very appreciative of any PicoC conversant person to cast their eye over this.
