Please be aware that electrical installations should be performed by a qualified person.
I need a switchable socket to connect some LED power lines which cannot be connected to the normal house lines. The Loxone solution is : https://shop.loxone.com/dede/smart-socket-air.html but it's quite expensive and I don't need energy monitoring, or any of the other fancy features. Is there an alternative that's easy to integrate with Loxone?
These TP-Link sockets were included in an Amazon Echo bundle at Amazon.de some months ago. There is a good chance to get them also second-hand on Amazon or eBay.
if you want to create your own, you can use sonoff s20 sockets (around £10 each), but you will need to reprogram them using a usb to serial adapter and solder some header pins onto the boards - once you do that you reflash them with espeasy and use loxone virtual outputs to turn them on and off, without using another server.
Diese Website steht zum Verkauf! diyprojects.io ist die beste Quelle für alle Informationen die Sie suchen. Von allgemeinen Themen bis hin zu speziellen Sachverhalten, finden Sie auf diyprojects.io alles. Wir hoffen, dass Sie hier das Gesuchte finden!
Thanks Christian, I will be using those TP-Links with my loxberry.
