- led strips are about 5 meter long. I need parts which need at least 10 meter of led strip. Hooking up 2 x 5 meter will probably not deliver the best lightning scene? I believe the best result will probably be by attaching the second strip to a seperate 24V power supply and also drive it seperately by using a DMX driver in the cabinet?
- problem arising now is, second strip will start some 5 to 7 meters from the central cabinet... I read different opinions of how long the distance between the power supply and the start of the led strip can be? 5 meter? 10 meter?
- what kind of wiring is used to hook up the led strip? Standard 1.5 mm wiring? Of cat 7 (which is substantially narrower, i believe 0.56 mm)?
- i also read you need to power the led strips from both sides?
Anyone having personal experience?
Thx!
