Heating installation what do I need.
    I want to change over to the loxone Air radiator valves. And was wondering what do I actually need apart from the Miniserver Go and the valves.
    I also have a few questions.
    Do the valves act as repeaters for the Air system. If not then I would need to use a Nano Air I guess.
    Can I just replace my standard on off thermostat time switch with a Nano Air.
    • 11238
    the Air valves have an integrated temperature sensor, so you need no other sensors. If you have your radiators somewhere built in (heat accumulation), you possibly add another better located temperature sensor in that room.
    The Air valves only act as repeater if they are externally powered with 24V. Using battery, they don't act as repeater, but will use other repeaters.
    Depending on your valves, you possibly need other adapters than the included one.
