Nano Dimmer Air failures - flickerring
  • ivantichy
    • 02.06.2024
    • 1
    I have spent some time dealing with failing Nano Dimmer Air(s). Has this happened to anyone else? Quite soon after installation, the dimmer fails, causing the lights to flicker and making them unable to dim. I wrote an article about how to fix this issue. You can read it here: https://github.com/ivantichy/loxone-nano-dimmer-air
    • 2592
    I know how hard such investigation can get if the problem just pops up erratically, additionally working on the hot side of such devices does not make the work easier.
    Good work and props for fixing Loxones problems
    • ledchab
      • 10.02.2016
      • 426
      since 2 days I have a similar problem with Nano Dimmer Air
      when first activated by motion sensor the light turned on and off with 2 secs duration - takes a few minutes than it looks normal
      must be hardware because in Config is steady on
